APC SMART-UPS BATTERY BACKUP SYSTEM, FOUR-OUTLET 420 VOLT-AMPS
Network manageable to monitor and control the UPS remotely. Audible alarms actively let you know if the unit is on battery, if the battery is low, or if there is an overload condition. Predictive failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Boost and Trim Automatic Voltage Regulation gives higher application availability by correcting low and high voltage conditions without using the battery. Adjustable voltage-transfer points maximizes useful battery life. Power conditioning protects connected loads from surges, spikes, lightning, and other disturbances. System VA: 420 VA; Backup Time at Half Load: 13.5 minutes @ 130 Watts; Automatic Voltage Regulation (AVR): Yes; Battery Recharge Time: 5 h.
Price: 147.89
